As long as they're a 4 x 108 PCD (which it sounds like they are) then yes, they'll physically bolt onto the car. You need to make sure they have the correct et offset though (should be stamped somewhere on the wheel, probably on the back), the standard alloys have an offset of et46, so anything fairly close to that should be fine. The tyres are a little narrow at 205 but I know other people on here have used them without adverse effects. I'd swap them to 215s or 225s when they wear out.
