Remove the Allen screw on the shaft. Lift the knob and twist to break the wires to the overdrive button. This I believe is the only way. Make sure overdrive is in the setting you want then just tape the wires off or you can splice in a button to the side of the center console for it and use an aftermarket shift knob
