Brake Pipe flaring tools
D1CKL
2,726
1,625
Dunfermline, Fife, Scotland
I have that exact set and used it on Jinxy.
It's perfect, and far better than the ones that need a clamp or vice. You can even use this on the car, to make the flare in a confined space.
Definitely recommend, and Mikey will hopefully back this up. It was my experience of his one that lead me to by my own.
Thirded (y) great set for copper and steel and so easy
Yes! I forgot that very important point - unlike others, it can be used on steel as well. So if you're not replacing an entire pipe section all the way back to a connector, it's ideal for the OEM pipes.
