Door Trim Removal
Thanks for the link.
Unfortunately, I cannot access it due to lack of permissions. Do I need to be a subscriber?
New to forums like this, sorry.
It is easy to remove. Just find the screws / torx bits around the edge of the door trim, the one behind the cougar head in the door handle and the 2 in the black tabs in the carpet on the bottom of the door. it should then just pull away.
Good luck.
yeah need to subscribe, just never noticed when i replied, tend not to check/look whose a subscriber, sorry
but peter's gave the info now
Nothing wrong in giving a little bit of free info out. This is the way I joined thanks to Alan's help when I first got my Cougar which had some small issues. but you are all correct, well worth joining up and you will save ££££ in repair bills for sure.
