Hi,
Wanted to ask.
The largest tube obviously is the one that fills the tank with fuel (you put a gas pistol in it)
The rubber hose is the hose that comes from Charcoal Canister.
Question number one is that is the very small diameter steel tube that goes along with the filling tube? What is the purpose of it?
Question number two is: Is there some kind of valve at the end of that rubber hose witch comes from the Charcoal Canister up to the filling neck? Or is it just ending without nothing? Then the valve should be in the Charcoal Canister itself?
I need to know witch one of those hoses/tubes actually lets fuel tank to breathe while I'm filling.
In my old car there was a solenoid that was opened during filling, so the gas tank could breathe, and was closed when driving, so the fumes were kept inside the system. How it works in the cougar?
Thanks,
Wanted to ask.
Thanks,
