Headlights
seanbra
Sep 11, 2014
5
france
Hi all.
I am in process of buying a 2 litre Cougar T reg 1 owner 40k miles for export to France.
I have read that the headlights have a lever for changing from right to left hand drive.
I would be grateful if anyone could confirm this.
Thanks
Sean
Hello Sean, there is a lever in each lamp unit to alter the beam but it is not designed as a permanent solution as it only blocks off part of the beam and doesn't give the correct spread of light for driving on the right.
Hi Procomm
Many thanks for your reply.
There are no Cougars for sale in France and used prices are very high compared with UK.
I have driven nothing but RHD cars in France for 13 years and it is not a problem.
Regards
Sean
Hi Quicksilver
Many thanks for your reply, it is very useful.
Best wishes
Sean
Hi Procomm
Many thanks
Sean
Hi D1kle
I will try thanks.
Sean
Hi
I have looked at all sources I know without success.
Thanks
Sean
Radio change
Hi
My Cougar should arrive from UK next week (low loader to France), it appears from photos to have the basic
radio cassette. I have seen on eBay Ford single CD players.
Are these a direct swap please.
Thanks
Sean
if you want to get a multichanger make sure you get a 6000CD with a rotary volume knob and not volume buttons, as those aren't capable of controlling a changer.
Hi Quicksilver
Many thanks again. It was as I hoped. I did not know about the 6006e which i will try to source.
I also read a useful article on retro fitting a remote control switch with pictures albeit fo a puma.
Thanks again
Sean
The audio remote kit from a similar aged Mondeo will fit BUT it can be a bit of a minefield due to varients in the wiring.
I believe there may be a couple of kits for sale on the forum at the moment.
