Hi all, thanks for any help in advance, my son got a problem with power steering or loss off, went and had a look and drove it home, and there is no power steering.
Had a look, belt is on and under tension, fluid is full although its black (possible seals, not just dirty black), if you try to turn steering it sounds as though the pump may be trying to strain to supply pressure but dosen't, also whilst trying to turn steering if you look into resevoir can't see any movement of fluid, suspect pump may be shot. anyone have any knowledge of these, didn't know if there was any electrical sensors in system that may cause problems, as you get in the electrical power steering systems that are around, i know that most of this is a mechanical system but they do addd senors/valves in attemps to "improve" system
whilst driving it might have seemed a bit easier as revs increased, but could just be as speed picked up it was a bit easier to turn as wheels were rolling
cheers tony
cheers tony
