Hi guys, My IMRC unbit seems to have developed an intermittent fault, It wil cut in nicely at just above 3000rpm as it should, but if i hold the revs above 3000 for a period of time it just shuts off and wont work again unless I switch the ignition off and restart the car!!
Has anyone else come across this problem?
I have installed an led to indicate when the imrc is active so I can see clearly when this problem occurs!
Help!!!!
Help!!!!
