Mk 2 mondeo audio control stalk
The Amazon
1,498
1,603
herefordshire
While looking round Harry Bucklands car salvage yard in Church down Glos i spotted a Ford mondeo v6 ghia x, it has the audio control stalk on the steering column which i think is a swap for the cougar one, so if anyone wants one they should pop over there quite quick as they seem to have a quick turn round on stock.
Matt, if you want the whole kit, as well as the stalk, there will be a module on the back of the bracket(pull down to remove)above the accelerator pedal in the driver's footwell with two looms one going up the steering column to the stalk and one heading off behind the centre console to the HU. The one leading to the HU is in two sections joined by a grey plug; to make retro fitting easy make sure you get both parts of that loom and the grey plug. There will also be an earth wire coming off the module to a 10mm nut to the right of the driver's footwell.
You will also need the column shrouds as they are pre-cut to take the stalk.
If it's a different Mondy to the last one you looked at in there check it out for the front and rear footwell lamps please. (y)
Now i am glad i did not try to take it out and sell it on here...lol
