MOT Pass
hardy
148
2
durham
Another year again one advisor n/s rear brake binding . Any idea of course for this .Lad said just keep a eye on it.
12 Months Great .
Well done mate.
As above, check the tension in the handbrake cable. If that's okay, get the wheel and caliper off and have a look for corrosion that would be preventing it from floating properly, and also inspect the surface of the piston itself.
More than likely break not releasing properlly take the wheel off and get some one to apply release the hand break a few times see if there is any movement on hand break. Failing that strip down break and thouroughly clean it and apply copper grease.
Just remembered you will have to use a wind back tool on the calipers they dont push in like the fronts!.
Yep and it'll be rusted solid! Just undo the bottom bolt and swing the caliper up, replace it with a STD hex headed bolt.
Cataclean is excellent as say very high emissions last year knocked mine well down . Also went for drive before mot up motorway.
nice one.
Similar issue on mine with binding brakes - changing handbrake cable helped but ultimately it was delaying the inevitable of changing the sticking caliper.
