G
greg hunt
I have now fitted sunroof from Wayne 45 fine and it works but after looking at all web info i am not that confident to use perhaps untill i use some white waterproof grease on it.To answer some questions earlier now that i have the old one out i can see that there is an allen key fitting in the centre of motor gear box that you can turn by hand but it is only of use if motor stops working and all linkages are ok, in my case motor / gearbox are fine but links sheared off so would not move roof.so if anyone needs a motor / gearbox /relay /frame/ black top i have these over so contact me.cheers greg
