Push Clip for inside panel for the wing mirror
elipton
987
693
Suffolk/Essex Border
One of my push clips isn't effective, and to replace it, I'm not sure what terms to use. The part I'm referring to is the white plastic clip that keeps the panel that sits between the door card and the beam panel adjacent to the wing mirror. Behind the panel is where the push clip sits and the bolts holding the wing mirror on.
This is a source of some annoying rattles, and I think it's been loose since I've had the car. What am I looking for?
I think i know the part you mean but same here, no idea what they're called. They are an awkward one to re-fit and tend to get flattened or lost. I've got a couple of spare mirror/parts so i'll check for you tomorrow.
is that the plastic retaining clip that the front of the doorcard clips onto or a different piece?
I think it is that one Paul, and i meant to check my "fixings" box today but completely forgot. So much going on here atm. I will, check tomorrow as i have to start making room for a car in the cave for weekend. :)
OK I think I found one. Is this it?
Sent from my E2303 using Tapatalk
That's the one!
I had the door off at the weekend and realised that the panel wouldn't stay fixed. It's either this part that's the culprit, or what it's meant to fix to. I suppose One possibility is to clear silicone the panel closed if another of these don't work.
Thanks Alan
