RWD Rear Wheel Drive?
Rippin6Gears
Dec 1, 2014
37
7
Seattle
It has to be possible, I read an article here in the USA, curious if anyone might have some info on converting to rear wheel drive in my cougar. Worth a long shot but anyone might have parts to do this?
If anyone has parts or info, it'll be there in the US. Over here, a couple of guys made 4WD Cougars. The conversion to just RWD would need quite some work.
I've been pondering this the last few days.
Essentially a transverse engine would be required, that in itself would require an awful lot of work, driveshaft and physically powering the rear wheels has been proven with the 4-be conversions.
The alternative, and this would require some rather expensive parts to be fabricated, could (please note the emphasis, this is hypothetical)be to fit free-wheeling type hubs to a 4x4 converted Cougar. It's common enough on old Land Rovers with fixed four-wheel-drive to make them economical and driveable to any extent on tarmac, then locking the hubs when 4x4 drive is required. It's well beyond my wit to imagine if this is in any way practical though. It'd be desperately uneconomical though, either that or somebody smart may be able to work some magic on a transfer box, but whether the Mondeo 4x4 transfer/gearbox is strong enough to cope with unsymmetrical power delivery to any great extent, I've not a single idea.
Theroeticlaly I guess with the Cougar having McPherson type suspension on the front (grr!) removing the driveshafts should have no effect on the suspension and steering mechanism. Again, this is well beyond my wit as a spanner-waver rather than a designer!
I've said it before and I'll say it again. The weight distribution is all wrong for RWD.
Of course you *could* achieve it, as many others have done with other FWD cars before. It'll be able do donuts and other things to prove it works, but it'll never handle well at moderate to high speed.
If you want to spend a load of time and money reproving it can be done then fine, but if you want a car that drives well, start with one that has been properly engineered and developed as a RWD platform. It won't have 40% of the weight on the rear wheels and the engine mass ahead of the front axle - that's for sure.
So it should handle like a Capri then jamie
Likes Cougar but wants RWD said:
Could do worse Rich...
Depends what it's all about though. Some people like the idea of a tail happy pig of a car who's back end pendulums from one tank slapper to the next. That's not my personal idea of fun as I prefer higher performance cars that can corner and put the power down fairly well but each to their own.
Cut a hole in the floor for the transmission and put the engine in that massive boot. Room for a V12 in there. Mid-engined RWD lunacy and a massive luggage compartment in the front.
¬_¬
¬_¬
Mad. Totally, utterly, unequivocally, certifiably mad.... but I'd love to see it done!
Ford Motorsport provide a (very expensive) kit to allow a V8 to fit in the focus. It uses the mustang rear end and a cradle that fits between the front chassis legs to mount the V8 longitudinally
Wonder if it can be make to fit in a coug
I haven't measured it, but I expect that engine would want to intersect the line of the bonnet.
**puts fist in mouth and squeals!!**
Dude. Don't do that.
