One of my tasks for this weekend was to spend some joyous time with a wire brush attachment in the drill cleaning up the forward end of the sills and floor pan whilst the cougar is jacked up in the garage waiting for the replacement rear engine mounting to arrive.
Alas some here will know the feeling, what started as wire brush and scrape with a blunt screwdriver became, I need to cut this out.
Heti now has a hole in the passenger side sill around 12 inches long and 3 inches wide, not to mention the 6 x 9 inch hole in the floor pan in the same area. The area in between is a little thin but might have to wait until next year. Strangely last year on the driver side I chopped out and replaced the central area but the sill and floor pan was pretty solid. I'm talking about the area that seems to have an additional plate across the underside, presumably a jacking point. But why you would fit a jacking point next to a main chassis box section is beyond me, I can only guess it was part of the production line requirements.
The bottom of the wings in front of the sill is gone on both sides. I presume this is non structural. To fix it properly I should take the wing off and plate it from the inside but I don't really want to take the wing off at the mo, I was hoping to put her back on the road by by the end of Jan to keep the miles down on alternative vehicles. Do I need to pull the front bumper moulding to get the wing off ?
