Hi,
I suspect that some of injectors are not holding pressure (leaking). I will perform a simple test - take the rail with all injectors off, and engage the pump. They should hold the pressure and shouldn't leak a drop out of them, right?
So taught, since the rail with injectors will be taken out, maybe it is possible to check how good do they spray. What should I do? Simply crank the engine, and they should spray right? as long as I will crank it, the injectors should spray? Maybe someone will suggest, thanks!
