First post!
Just wandering if anyone on here has put a turbo (or even twin, but my knowledge or budget won't allow me to do that) on a 2.5 v6 Cougar?
Wanting to do this to my Cougar, here is what I think (single turbo config):
Turbo, exhaust manifold modification 6-2-1 and put the turbo at the 1 then run into the exhaust as per(?), oil feed lines, some nice 3-4" pipe to run the air from the turbo and from the turbo to the front of the car where a filter will be shoved on so it can breathe cool(er) air and lastly brackets to hold the turbo up so it doesn't have to try and float. Ooh and an intercooler so more pipe.
I'm pretty sure I also need:
Larger injectors, a better fuel pump (larger flow) and when I'm finished an ECU remap or something like?
Do I have to modify compression ratio and if so is there a pre-made head gasket? Only looking to run 8psi boost. Will I also have to get forged pistons upgraded crank etc?
Turbo - http://www.ebay.co.uk/itm/GT28-GT28..._CarParts_SM&hash=item3cc9986819#ht_763wt_904 taking oil from just off the oil filter with a restrictor(?) size I'm not yet sure of and having the return to as high up on the pan as possible(?).
BOV will be something I like the look of.
Won't be starting the project for a couple of months and its on a budget but I will spend money where I have too, these ebay turbo's have mixed reviews but for the saving I'm willing to give it a bang (and hope the engine doesn't!).
