I love my car, always have but time after time she keeps letting me down with costly repairs. I've now spent more in repairs than I bought the car for (2.5 years) which is never a good sign. Is everyone else the same?
Sad but true, but we're going to see the death of more and more cats. When do we switch off the life support machine ?
the thing is it does seem a lot, but a lot on the list are items you would of had to repair/replace on what ever car you buy
tyres, brakes, oils, filters, plugs etc are consumables,some of the mods are also what you might do to any other car you bought, also fitting a LPG system on an older car will take along time to recover it outlay, also depends on mileage as to how quick you recover costs, as others have mentioned
also it also seem like you have been paying for for brake repairs a lot,do you trust that garage?
seems you've had
may 09, handbrake, brakes and calipers
july 10, rear dics's and pads
june 11, front pads, rear pads, caliper, pad kit, handbrake cables...
at least now you know whats been done, to this one. if you buy another you could end up going through a similar process all again
as for service's rapid fit or the like do oil and filter change offers, take advantage of these as these are good value, the rest of the service you could do yourself as if you read what's done it's check's, check brake fluid, check powersteering fluid +other levels, tyre pressures (if your lucky)tyre tread depths, most of the service are just visual check and report, they don't do a great deal else, your paying someone a lot to do basic checks that you may well be doing yourself anyway.
if you like the car and your happy with it then thats what matters, also if you can have a bit of fun driving it so much the better
