My v6 has been largely unused for the last few years. During it's partial hibernation I have;
Fitted St 200 airbox
ST 200 throttle body
Modified the bracket to accept the appropriate throttle cable to match the throttle body.
Changed the exhaust system to a twin outlet type.
Changed the exhaust manifolds to tubular type thereby removing the two lead cats and the pipe that links the rear exhaust manifold to the inlet manifold.
Blanked off and removed the EGR valve as it is now redundant.
The main cat is still installed.
The vast majority of the components have been sourced from your good selves
The car is now in use and during the off time and changes has developed an annoying problem in that the engine often race up to 3k, typically when I slow down and move to a lower gear to park.
I'm pretty sure it's doing something similar on the motorway, it just doesn't slow down as much as it used to when I throttle off, I'm braking a lot more than I used to.
I fitted new gaskets on the inlet manifold, nor does it sound as if it's sucking in air around the inlet manifold.
I imagine maybe some sensor has failed on the injection system, the lambda sensors have effectively been changed as I left the used ones in the tubular manifolds that came with them but so far as I know they would not control the fuel mixture to that degree.
Anyone else had this problem after similar conversion ? Thanks in anticipation, Mabo.
