Had the car on the road now for 10 days and everything seems fine. I've booked her in for a total respray next week, as by then all work will be finished, except for a remap with Collins Eng and getting my new reg plate sorted with DVLA.
However, after seeing Active's thread re: last batch of Eibach dampers. I decided that now is the time to replace the suspension and also change the front wheel bearings. My decision that now is the time, basically came down to the fact that Eibach have now discontinued manufacture for the Cougar, so its simply a case of 'grab em while you can'. I would have preffered to use the Eibach springs as well, but they are like rocking horse cack and the only place I found them was on German ebay at over ?ú200 + delivery, so I decided the PI springs, again from Mitesh, would be ample for my needs. In the back of my mind I was also thinking that the dampers on any car are really only good for around 30k miles and they will progressively deteriorate. You wont likely notice any difference as you are driving the car everyday, everything will seem just the same, until that is, when you happen to use (or sit in) another motor with replaced struts and realise just how much your car wallows and leans on them bends.
So my cash cleared with Mitesh on Friday (BTW top deal m8 on the package price, many thanks), he then informed me that he would send out this morning so that the parts wern't sat in a Parcelforce warehouse over the weekend. The PI springs arrived this morning (along with the wheel bearings from ebay).
So after a kip on the couch I decided at 4.30pm to strip down the fronts.
In just under an hour, the fronts are off
I would have done the rears as well, but having only 1 set of axle stands, they will have to wait until I finished the fronts.
While removing the n/s I noticed a puddle of oil
Looking closely, the n/s diff oil seal is leaking (I must have snagged it when putting the d/s back in, oops!).
So now its another trip to Fraud in the morning to get ripped with a diff oilseal, at least everything is stripped down making the job easy. If I wern't replacing the suspension I'd have been proper ragged off with having to just replace the seal on the diff. I must try remember while I'm getting shafted again by Fraud to get a couple of trackrod end nuts, as I'm not happy reusing old one's, like I ended up doing after the main refit.
I will post back tomorrow when the struts arrive, I need also repaint the hubs and fit the wheel bearings. The front end running gear will then be 100% brand new. Once all's complete, I just need fit the st200 alloys and get the wheel alignment sorted (and do the backs and fit the st200 antiroll bar and bushes).
Many thanks to Mitesh for doing me a cracking deal and for his speedy service and for keeping me up to date on my order progess. Top service bud, couldn't expect any better!
Cheers
Ste
Cheers
Ste
