A work in progress....
I'm sure if i had a v6 airbox i could cut a vinyl oblong to cover the top, leaving a 10mm border? with a black cathead on top of it :cool:
Thanks Al, that would be great, however the measurements are: 21.5cm long x 12cm width, however as you look at the top of the airbox you can see another rectangle within it which is 18cm long x 9.25cm wide - which the sticker could sit within, therefore I would end up with a red background sticker with the black frame (original colour of airbox) around it. Think that would look cool.
That would look good, totaly red wouldn't match your colour scheme I don't think.
Good idea on the IMRC cover, paint it black to match the UIM with red letters
sent with a click 'cause my lick don't stick
I'll be in V6 company tomorow, so i'll take a peek :cool:
Tim, can you send me a photo directly overlooking your airbox :eek:
Call round by all means mate as it would be ideal to get the "fit" correct, but the reason for asking is, i have a st200 airbox here, but it has embossed text on the top of it which would interfere with a sticker. Is the standard V6 airbox flat?
I'll pm my addy (y)
Al, the stock V6 one also has the raised text; it says air filter in 4 languages.
Errr...mine hasn't, it's completely flat on top with no raised text - if you look at the pic's you can just see it off to the top right of one of the photo's. Al - I'll take a pic tomorrow to show you :)
I've got a st200 one here Tim, ideally i just need the top to try it once the sticker is drawn on paper prior to cutting the vinyl. Providing the actual box measurements are the same as what you supplied me, then it doesn't matter about the embossing.
Ok, cool...just PM'd you
Al do you need a standard air box to play with? I have a couple and I believe hip is heading your way after dropping in at mine on Sunday
