Anyone fancy a spot of wiring in Oxfordshire?
Relliott6879
6,936
5,491
Fleetwood
Guys, I've got a small wiring job to do on Saturday (16 Nov) which, theoretically, should be nice and easy. The thing is though, as much as I tell myself that it's straightforward, I'm kind of cacking it. :cry:
What I'm trying to achieve is the fitment of a pair of facelift rear light clusters to our Fiesta, the reason being that they have a fog lamp and reverse lamp in each cluster, the early clusters only have a fog lamp on one side and a reverse lamp on the other. As most of you know, we're moving to Germany in the coming weeks and the current set up won't pass their version of the MOT.
I'm working from the guide in this thread http://www.fordownersclub.com/forum...5-prefacelift-facelift-brakelight-conversion/ and I'm currently at the stage of having wired the new multiplugs onto the new clusters. What I need to do next is cut the multiplugs off the car and fit the new ones.... and that's the part that scares me. Although it seems straightforward in theory, there is no option of this not working and once I've started I have to finish, or I'll have no rear lights. I obviously can't drive anywhere mid-task either, for the same reason. I spoke with Chris Prickett tonight, who made the very sensible suggestion of buying some scotch-blocks and cutting the multiplugs from the car with enough of a tail that I can re-join them to their original wires if absolutely necessary.
What I'm after, more than anything, is someone who is confident in this sort of thing and has at least a working knowledge of electrics (I'm not and I haven't) to come and watch over me, being on hand to help out if it all starts to go a bit Pete Tong. It goes without saying that copious helpings of bacon and tea will be on tap, as well as beds and beer if required.
Location wise, I'm in Grove, Oxfordshire (OX12 7JD), virtually next door to Williams F1.
I honestly don't think you're going to have any trouble with this at all Rich. That said, I do understand you wanting backup with you.
I think the only thing you're going to have to careful of is the new cable runs across the car to wire in the second fog and reverse lights. You'll need to make sure they are properly secured and can't rub against anything.
Sorry I can't be there, and best of luck!
I know of this conversion.
I can do this for you, but I am between Bedford and Luton.
I'd be dubious about trusting lamps to 'Scotchlocks' but I am a pedant with wiring.
Regards,
Andy
Rich, I'm pretty sure I'll be stuck at work on Saturday but I won't be going very far from our grain store so if you could come to me I'll willingly admire your handiwork and be on hand 'just in case'.
Just to be clear: that's not what he meant, nor what I suggested.
I said that he should get some repair blocks in, in case he had to put an old cluster back in so that he could move the car legally.
Precisely this. The scotch-blocks should hopefully never be required; they would only be, and were only ever suggested as, an emergency fallback. Of course, the ideal method of rejoining the wires (if required) would be to solder and heatshrink each one. However, I neither own nor have any idea about the use of a soldering iron.
Benham. you edited your post to insert a back-handed dig at Chris's perfectly reasonable advice after I had thanked you for your offer of assistance. In light of that, thanks removed.
Not knowingly, can't say my mind works in that way....
I'd use water tight spades and heat shrink, Scotchloks in my not insignificant experience of automotive wiring are always a) bulky b) problematic.
Up to you how you do it to your car? My offer still stands, didn't think I'd get ****** replies for offering my time and services for free to help you with your car?
Regards,
Andy
Regards,
Andy
I believe, in my not insignificant experience of pedants, that you are being deliberately obtuse and that you understand perfectly well that the scotch-blocks were only ever suggested as an emergency, temporary fix. Nobody, at any point, has suggested wiring the lights up in this way and leaving them as a finished job.
I did say I was a pedant with wiring...
Up to to you chap, if you fancy a trip over the boarder to Bedfordshire I'll sort it for you.
Regards,
Andy
Benners, I think you are fighting a losing battle in your attempt to be popular.
I say this on the basis that you seem to truly believe you are better and more knowledgable than any other person and take personal gratification in trying to belittle. Ah judo chop
Regards,
Andy
I would solder the joints and heat shrink them, its not like your going to change them back at a later date. Out of curiosity Andy, what problems have you known with scotch locks, used correctly they make a great contact and are water tight, only issues I have seen are from people re-using old ones
cheers
Paul
