I've got electric fencing wire and metal staples if we run into difficulties, Rich![]()
What time on Saturday is good for you mate?
Rich, I'm pretty sure I'll be stuck at work on Saturday but I won't be going very far from our grain store so if you could come to me I'll willingly admire your handiwork and be on hand 'just in case'.
I would solder the joints and heat shrink them, its not like your going to change them back at a later date.
That's actually a very valid point, Paul, and something that hadn't occurred to me. Problem is, I've no idea how to solder and learning on a car that I absolutely have to have functioning correctly may not be the best plan!
I said solder before paul,not fair iam going to spit the dummy out now
Twist the wires together, gaffer tape the clusters in place, job's a good 'un!
I think that the solution you have - using an aftermarket multi-plug (which I'm guessing has friction-fit or clip connectors?) - is perfectly valid.
But next time I see you, I'm bringing a soldering iron, some solder and some scrap wire so you can play if you want to. It's not hard to do, but takes practice to do well.
Its Cool paul i leave the wiring and soldering to my mate since he is a spark and iam not,i will do simple taks but cant solder to save myself
actually having looked at the wiring diagram you may aswell just run the cables properly rather than joining them, you will be utilising the original connector and from what I can see ford already have the loom fitted so its just a case of connecting the new wires to the correct pins and jobs a good un![]()
