i think you should.
Ok, do you know how long the battery needs to be off? as changing a panel filter literally only takes 2 mins
i think you should.
Enough time for a cup of tea I've been told - but make sure that you have the radio code to hand 1st (like I didn't :mad2![]()
I have an aftermarket stereo fitted, so should be ok??? lol![]()
Ok guys.
It's not vital to reset the ECU when replacing a filter, as the ECU will relearn on your next drive out anyway.
If you do want to reset it anyway! rather than disconnecting the battery and risk losing your stereo settings, just pull FUSES "4" and "11" from the fuse box next to the battery. Do this before you start work. By the time youve done the ECU will be reset, so just replace the fuses.
Fuse 4 is fuel pump and fuse 11 is ECU.
Happy tinkering![]()
many thanx for info! ordred kit from racebits tday! will be pullin fuses soon.
