Just a quick query, will an aftermarket performance exhaust of an Automatic cougar v6 fit directly onto a manual? Or is there some modification/fabrication required?
It should be a direct fit, just check that the flange that bolts to the flexi is a 2 or 3 blot on your car before you buy one. then make sure the system you buy is the same..
