Bonnet Struts
Thanks Andy, i will take a look, I was wondering if Alan could measure the length of his struts for me to see if they are the same size as the mondeo ones? that way i know i can use the how to guide exactly.. :thumbsup:
Add - be interested in how this goes for you as it is something I am looking at doing in the very near future
I will post up when i have done in my progress thread Alex, I think i have found the brackets from SGS I just need to check the ball diameter on the struts..
Sorry add, I missed the part about measuring . I'll check for you today.
sent from Pid using Tapitap wotsit
Thanks Al, mucho appreciated chap.. :thumbsup:
Hope this helps Add, just shout if you need any more info.
Measurements on my redline struts:
Fully extended including bj's = 520mm
Fully extended ram including bj = 235mm
There is also a part number printed on the struts which iirc i once gave to SGS in the early days and they said they could produce struts to suit, including any fitting parts needed.
Excellent, thanks Al, i will measure mine when i get chance and see if the fitting guide measurements will be the same for mine.. :thumbsup: if so then all i need to do is order the brackets which are £3 odd each and fit them when the weather is better.. :)
