Probably not the most sought after combination but has anyone done it?
Are tow bars easy enough to find/fit to the cougar? Is the cougar OK for towing?
My reason for asking is that we had a wobble box a couple of years ago, and enjoyed it and are thinking of getting another.
But due to the fact that I passed my test after 1997 we are stuck to only being able to have a max train weight of 3500kg. Our other car is a Galaxy which has a max gross weight of 2430kg which only leaves 1070kg max gross permissible weight for the caravan.
As the Cougar is lighter and can't carry as much I can actually tow a heavier caravan with it.
The info I've found suggests that the cougar has a max gross weight of 1685kg, so I could legally tow 1815kg (although the data also said the cougar had a max towing weight of 1500kg). So with the cougar I can tow a 1500kg caravan with plenty of room to spare for the law, with the much more suitable ford galaxy I can only tow 1070kg - stupid isn't it!
The extra weight gives a lot more choice, most of the ones I'm looking at are around 1200kg
So has anyone towed with the cougar? I guess they'll be alright as it's basically a mondeo and plenty of them are used.
What would fuel consumption be like? With the galaxy on a good run we get 50+mpg without the caravan - with the caravan we are lucky to get 30mpg.
The cougar does about 30mpg on a good run, so I'm guessing I'd get around 15-17mpg with a caravan?
Please don't say anything nasty about caravans
