Digital Heater Control
ISG
122
17
Lithuania
Hi,
I have a mechanical controls (three dials). There are some digital controls (2 dials, display, buttons) for sale. I'm 99% sure that they are not swapable, for obvious reasons, but common, its a Ford, and everything is possible :teeth: So how it is? :)
Digital display is usualy if you have semi-auto climate control, this was available on the V6, it has a temperature guage display instead of the dials. It is quite an interesting set up using air pipes (have had it apart myself fitting a stereo in dash) don't know how easy it is to retro fit mind
It is possible as several kits have been sent from the UK to the US. The semi-auto system wasn't fitted as standard over there either.
You will need the whole system including the vacuum pipes etc, not just the front control panel.
Try asking in the breaker thread if someone is willing to strip a system out and post to you?
Might be best for you to try on NECO for instructions/problems?
http://www.newcougar.org/forums/forum.php
