Review: 5/5 ERBAUER LED RECHARGEABLE WORK LIGHT 20W 7.4V
David`
1,806
2,988
Peterborough
Needed a portable light to use when doing under car repairs lying on my back as I'm sick of using an inspection torch that I'm always dropping. I was undecided betweeen the 20w, 30w, or 40w but I decided to get the cheaper 20w item and I'm very impressed
£32.99 at Screwfix
Underneath the car with the light on the floor on its stand facing upwards, camera flash turned off (its certainly showed up all the imperfections from my undersealing...)
Build quality: 5
Ease of use: 5
Value for money: 5
Hard to say about how long it'll last or how good the battery is but after the first use I'm definitely impressed. 5/5
That does look a good light to work in. Can the charge lead be connected while the light is on?
edit: It does state: "5hr charge time" "3 hr run time" which i think is good enough for a session under the car.
Reactions: David`
One of the reviews says it will run on the lead if you forget to charge it. It also comes with a cigarette lighter lead as well as a normal plug
Reactions: Pid_16V
ive got one of these too altho mines the 30w one..
fantastic light that spreads the light instead of just a spot or area.
has a charge indicator so u know when its getting low..
did u know u can get a tripod for these to attach to.
ive had mine 7 months now and its given no problems and the battery lasts good still..
