Thank you for all your advice, I now have a plan. Remove spark plugs give each bore a tiny squirt of WD40 or similar. attempt to turn engine by hand on bottom crank pulley. if it turns ok. change oil & filter + fuel filter (cannot remember when last changed). put in fresh fuel, (tank empty when parked up). unplug coil pack, turn over till oil light goes out (good suggestion, thank you). plug back in and attempt to start. If it starts run for a while, allow to cool and check for leaks, if all ok. replace drive belt, drain coolant & fill with fresh. After that restart run up to temperature and monitor for a good while. If engine ok. time to start the rest, check underneath for corrosion, Bodywork, exhaust, brake pipes, etc. unsieze handdbrake (might need cables) and clean up discs, front and rear, replace pads if required, change brake fluid. replace rear shocks (both leaking when parked up). Take for mot and see what happens, will be a good few weeks before MOT time comes aound, will keep you infomed, cheers,, Hornett.
