Ok thought I would share these pics of an install we did for a guy who drove from Scotland (5 1/2 hours) left his car for a month and collects it tomorrow.
Wanted install to look as oem/subtle as possible.
Kit list
AMPS
JL Audio Amp for tweeters
Hertz EP4 for mid woofers in doors
Orion D2400 for sub
AudioControl 24 (active crossover)
Speakers
Focal mids
focal tweeters
FI BL 10" sub
Headunit
JVC double din media centre.
The job was big everything running active so Wires needed running into the doors for tweeters and mids, doors deadened, 0 AWG running front to distribution block in the glove box (behind passenger seat). Dash had to be removed to install headunit and as the car had the "upgraded" BOSE system installed wiring had to be done from scratch too, headache doesn't even come close! a full day was taken just to wire the car with nothing else getting done.
Ok pics
The car
First the strip down.
Deadening added to doors roughly 70-75% coverage
All added wiring was soldered AND heat shrunk
Tweeters mounted in stock location after some trimming with a dremel
AMPS!!!!! Headache all three amps had to be mounted in a glove box so I had to get creative you will see how close I was for space in the final shots of them in situ we are talking 1/2" clearance.
ok and on to some finished shots
Finally where the amps/fuses/audiocontrol all hide!! nothing on show but all accessible if needed by popping off the cover to get to amps or lifting the lid in the glovebox to get to fuses.
Kit list
AMPS
Orion D2400 for sub
Speakers
Focal mids
focal tweeters
FI BL 10" sub
Headunit
Ok pics
The car
