Watching all of this talk about V6 mpg etc I was wondering if anyone had put a dieslel lump into a Cougar?
I really don't get the diesel bashing you guys obviously haven't driven any distance in a decent BMW diesel I had the pleasure of using one regularly a 335d coupe with the M sport kit(suspension) I'd take it over a lot of the petrol "sports" cars I've driven, I mean most people class the civic type R or focus RS as a sports car both of which I've driven at a comparable age to the BMW and they don't even come close. Likewise even a XKR (first shape) maybe my interpretation of a sports car isn't the same as others but IMO it should have good torque, good handling gain speed rapidly and be involving to drive the BMW was all of these and felt in a lot of ways like a bigger MX5 (series 2) which I have driven and enjoyed immensely.
Some of you should really try a modern diesel in a decent car before you all go on about how rubbish they are it isn't like the cougar is particularly good at anything! It's a nice car with average speed and comfort that handles fairly well!.
Hmm I guess I never considered my v6 to be 'low' on torque at 2000 rpm.Wouldn't be much fun - the V6 petrol is pretty low on torque at 2000rpm so every time you came to a hill you'd have to change down to 5th or slow down. The 6-speed in the ST220 is lower geared and cruising RPM much higher than the diesel.
For comparison, my 3.0 X-Type still with a 5spd manual is taller geared than the Cougar, and cruises at 2700rpm at 70mph, and has surprisingly little grunt left over. The 3.0 S-Type with 6speed Auto cruises at 2250rpm at 70mph, and always downchanges if you try to speed up or go up a reasonable hill. Not a problem with a good auto but a PITA if you have to do it manually just to maintain a steady speed!
If you reduced the gear ratio to give a 2000rpm cruise at 70mph instead of 3000rpm, the change in gearing would yield 50% less torque at the wheels compared to what you get at 2000rpm in 5th gear at the moment. Add in to that the fact that the aerodynamic drag at 70mph is more than double what the car needs to overcome to accelerate from 2000rpm in your current top gear, I think all will agree that the 2.5 V6 simply isn't man enough for the job of cruising at 2000rpm at 70mph.
Like I said, the 3.0 AJ-V6 cruising at 70mph gives pretty lack-lustre in-gear performance on the motorway, and that's an engine which is a good bit better developed than the Ford version and puts out 231bhp in X-Type form with variable valve timing and more flexible intake runner length control, both of which substantially improve the mid-range torque over the Duratec - and it still struggles to accelerate the car from 70mph at 2700rpm. I absolutely wouldn't want it geared any taller, or it would be absolutely useless in top gear at legal speeds.
