Hi guys, firstly i want to encourage you all to drop your oil pans and check your rod bearings, unless you want to end up just like me. Engine was perfect, no oil consumption at all, no cooling consumption, compression excellent, all the spark plugs equaly healthy colloured, and bam, rod bearing decide to go
Now if i wont get away only by changing them (and 99% i wont), i will have to throw the engine away, will not risk to rebuild, because metal shavings were all over the oil pan... better just throw another engine and change those bearings in advance.
NOW THE QUESTION IS:
What do i need to swap the engine and make it run? I know that some cars need the same ecu, same immobilizers, or how do you call them... so i need the whone engine and what else?
Thaaanks!
Thaaanks!
