I've been trying to prepare a part for the cougar ready for spraying but it's not gone well.
The part was already in the right colour but was scratched. The scratches were sort of like where the paint had chipped off. The primer below wasn't scratched. I started with 180 wet and dry wet on the chipped areas to blend them in, I then went over the whole item with 320 wet and dry to remove laquer etc.
After serveral hours of sanding it looked good enough to me so I thought I'd have a quick go with some primer to see what it looked like.
I had a quick look through the shelf in the garage to see what I could find and found a tin of "Filler Primer". The spoiler was quite warm as I'd been sanding it inside, so I thought I'd give it a try. It seemed to spray on perfectly - no runs and was looking nice and flat, but then as it started to dry it started to craze. The first patch appeared and I thought that perhaps I'd missed some laquer, but then a second patch appeared on a bit that I'd rubbed down to primer - so it shouldn't be that.
Any ideas on what I did wrong?
Maybe sprayed to much?
I've left it to dry fully, then I'll have to get the wet and dry on it again.
