Ok so so far ive replaced the battery , topped up the PAS fluid and replaced 2 clips on the inlet manifold intake tubes , she is now running like a dream as its no longer leaking air on the inlets and the PAS is as quiet as a mouse , but i still have to locate the leak at the weekend . Ive also stripped out the front grill which had a bit of wire mesh fitted in to it which wasnt factory fitted and someone had sprayed it silver including the original grill. Ive cleaned it up and re-painted it black like it should be and i think it looks much better . On looking for the rust , well the only real bit i can find is on the o/s/r sill to floor a patch about 4-5 inches which should be simple enough to sort .
Heres a couple more piccys after a good soapy scrub .
The cougar checking out its new play mate
So this weekend comming is clean the inside and have a good look around the under side and work out were to start next
