R
radiogareth
Hi, my trusty 1992 Scorpio estate is getting a bit long in the tooth and I like my leather, air con and cheap Ford parts. Saw a Cougar locally and thought "What's that??". Now I know. It is also about time I had something more rewarding to drive
I'm looking for a Blue Manual (had enough of expensive auto boxes on Scorpios thanks) with leather but have some questions perhaps people could help with before I spend my hard earned.
I'm familiar with the 2.0 Zetec (son has one in his Haynes Roadster) and I had a V6 Cosworth in an earlier Scorpio. That expired the timing chain at 116,000
which was replaced by a low miles donor. I have endured my Scorpio 2.0 DOHC for 40,000 miles and now I want the option of a bit more fun, somethimes, hence the V6. Does the 2.5 have any weak points I should be aware of? What sort of mpg are people getting - I can tease the scorpio up to 38mpg on a mway run?
I converted my Scorpio to LPG and have been 100% pleased with it - single point closed loop system.
Has anyone on here had theirs done recently (I have had a search through the forum) and if yes, what size tank did they manage to squeeze in to the spare wheel well, which I presume is a full size spare? Is it the v6 that is electrically complex - any special reason why? WHat are the V6's like to work on - accessibility nightmare or what?
Are decent roof racks available for the Cougar as I sometimes need to transport a bike. I'd also like a towbar, not least it stops people using my car as a parking aid, plus I do sometimes need to drag something!
Any rust problems I should be aware of - they are now reaching that point in life where it may be a problem.
Thanks!!
Gareth
Thanks!!
Gareth
