where is fuse box in car?
89clipper
Jan 30, 2012
30
stafford
Hi, i have read that the fuse box should be under the dash on the drivers side, is that correct because i cant see it. Help please.
You've got 2 fuse boxes on your shiney new cat, one under the bonnet, next to the battery, and the second is under the passenger side of the dash - crawl into the footwell and look up - the search bar at the top right of the page is also a good help :thumbsup:
Where you have read drivers side that was prob refering to a Lhd car. As above, access into the box i believe is a little catch on a sort of cam and the box hinges down for access to the fuses.
Yeah i found it thanks. I am still banging my head against a brick wall as to why the heater and blower only works 1 in 20 turns of the ignition. Damn cold. Help please.
No, when it doesnt work, nothing works at all. The bloke i bought it off put an old stereo in it to sell it so i am wondering if when he stuffed that in he pulled a connector loose or trapped a wire or something to the heater. The stereo works as and when too.
Probably not got the vac pipes back on properly, probably even bodged the stereo connections as well. It's a dash out job, all relevent info for this job is in the subscriber "HOW-TO" sections.
Thanks for the reply, i just pulled the stereo out and all is well there now. But while i was fiddling i turned ignitoon on and the heater display and blower kicked into life then i turned ignition further to fire up engime and it all went off, could it be worn ignition barrel and or key? Ps will subscribe when i get paid. Thanks.
