I'll have a look for the loom but how do I lift the fuse box cover off to check?
Ian, you'll probably see more by taking the battery out and gaining access that way.
That's how I'd do it, there may be a more elegant existing link but it's certainly going to do what the OP wants.To save bypassing buying more lights, wouldn't it be possible to connect the lights directly to ignition?
Bringing this thread back to life. I've dismantled the light switch fixing and had an issue with getting a LHD light switch to fit in a RHD fixture. This can be fixed by whacking the top plastic junk off (that Ford seem to have purposely put there just to be douches about using nonRHD/LHD parts). I've affixed the double pull switch, which has right and left parking lights that don't actually work as I only get both on or both off, probably wiring. Problem I've got now is that when I pull the switch out I get the light that front fogs are on (which I dont actually have yet so I'm not sure if they're working) but if I pull it out again the back fog lights do not come on, neither does the light on the dash.
Any ideas?
