Hi, could someone please share what aftermarket struts are you using with lowering springs? Brand of struts, and springs please. I think that mine Monroe reflex struts raised front end a little...
Thanks for help!
The front of the Cougar sits higher above the wheels than the back does, that's just how it is, if you lower by the same amount front and rear then this won't change. If you want to bring the front down more than the rear then you need springs with a bigger drop on the front than the rear. A set with -40mm front and -20mm rear would probably do it.
All i asked is a brand of what you are usingi understand that front is higher in stock...
I have monroe reflex e4942 in the front and e4943 in the rear with apex lowering springs, also tried spax springs - the front is still jacked up compared to the rear which is perfeclty lowered![]()
yes i need frint to be lower, i guess i will have to cut one coil, and modify strut piston a bit, i will shorten it 2 inches and rethread it, so i wont bottom out them and kill them in one season
