Just thought I'd keep people updated, on what I'm doing to my cat
Fixed Cigar Lighter, Bad wire & Blown fuse - Now Sorted.
Stereo was faulty, have temp fitted a Single din unit until I get a replacement.
Boot cover String repaired and a Bolt Found/Fitted.
After running heater on full for 10mins, engine seems to be cooling better, so I'm thinking a coolant flush might be in order.
Front Disks actually look like they are corroding, so really must get these alloys off.
Found a set of 4 Fox 18" Alloys on ebay for £80 4x108 Bolt Fittings, I assume these would fit? (205/50/16)
As I understand it, there were only 10 Alloy wheel keys made for the Alloys, so maybe someone else's would fit?
Have been quoted £50 to have them force-ably removed.
Power steering hoses actually look a bit rough, but Is not currently losing fluid. Also found an after market Cooling Pipe for £50+P&P
No obvious leaks from Radiator, Hoses. But I think the Water pump sounds a bit rough.
Heat shield near front exhaust pipe is rattling/loose
Only way to repair scratches is a respray
