naturally aspirated it would need a 3L bottom end, high rise cams and ported and polished.
You think that would be enough to get 75BHP over the stock 170BHP ?
It just seems to me that is a massive increase.
coupled with a remap to increase air fuel mix and dial back the bottom end torque level yes that would be doable with said enhancements to the stock engine, if I recollect correctly Damien the founder of UKCougar was not far from that figure with his Cougar which now is under the care of Will LeaperYou think that would be enough to get 75BHP over the stock 170BHP ?
coupled with a remap to increase air fuel mix and dial back the bottom end torque level yes that would be doable with said enhancements to the stock engine, if I recollect correctly Damien the founder of UKCougar was not far from that figure with his Cougar which now is under the care of Will Leaper![]()
no it has the 2.5 heads on itWell we will see what the op has done then. I look forward to it.
I always thought Damien's one was a full on 3 litre conversion ?
no it has the 2.5 heads on it![]()
