That looks very good.
'crick' is 'jack' for us.![]()
The Cougar that Jack built-)
buy the headers and worry about the fitting later, worst case senario is you have to buy a new catalytic converter and flexithis is something i have had to do and really isnt a big issue
Thanks for the advice
well with some patience, i'd like to find the right exhaust manifolds...that fit 100% for my model
but without the 2 little cat...i think i have to modify or remove the egr valve
'cause in my model...a little tube starts from the little left cat and go to the egr valve
for the recirculation of exhaust gases
Or give it a bit of thought and buy the correct one in the first place...saves wasting money on a new cat and feeling foolish afterwards.
this is my idea-)
yeah i don't like foolish afterwars
I agree...search with calm ad find the correct one-)
even used...in good conditions
somebody knows something about the "voices" to the empty at low rpm
with sport manifods without the 2 little cat?
maybe it's only voices...maybe it's true
do they do a 2 bolt one now, when i bought my toyosport set they only did the 3 bolt type
well 2 bolt in one now...even more complicated
in fact, the Cougar has his years
so hard to find special parts such as exhaust manifolds
So you have the exhaust manifolds sports toyosport?
Well if you want I buy yours manifolds!!
Yes. So he can pick the correct one, not "worry about the fitting later"
well there's a lot of options...
but the correct one obvously it's the right choice
now i understand how to post smilies..
first click on smile...then write the code...
i'm almost a genius like A.E. :beer:
Today came the 4 gas shock absorbers
and 4 sport springs
2 rear shocks are ok ...
one of the two front shock absorbers has a problem
now i can post the smilies...
but sometimes i have problems with the pics...
I click "from computer"...then "basic uploader"
I choose the file...and the file appears after 3-4 attempts
what is the exact procedure?
well i hope you can see the picture...
I do not know the exact name of the piece that broke off
I tried for a long time but I cannot find the name
the piece that broke off is this:
as you can see right into the shock absorber is glued
into the shock absorber on the left came off...is in my hand as you see
what is the name of this piece?
I can fix it? ... or is it better to send it back to the seller to ebay, and make me have another again?
above this piece is written: "Do not open"
