Marks picture is the 3bolt cat, there is also a 2bolt version that doesn't use the flexi
Unfortunately they are not interchangeable, you have to change the y-pipe to change the Main Cat from 2 bolt to 3 bolt or vice versaThat might explain why the new one ive got looks different, ill have to get under the car and have a look which one ive got
Dan, that looks to me like the one on the left in the photo in post no.5.
It appears as though the one you have has a shorter cat body and a pipe rather than the tapered cat in the post 5 photo.
Dan, that looks like a sports catalytic converter, is it stainless?
All cougars use the flexi section, early ones are straight cats and later ones have the Z cat to accomodate the lambda, the different Y pipe version with no flexi and a tapered cone is from the mondeo
Edit.......looks like a decat to me......
So which ones are straight or curved then?
only ones i've seen with no flexi have been robbed from a mongy
