Running a Cougar as a third car (in a house of two)
Cheers Mako, just created an account and uploaded a couple of pictures; let's see if this works. Usual apologies for phone pics and size of post :)
Rear 3/4 view;
From the boot, last trip out was a tip run. And yes the struts are borked!
Noticed this gap on the drivers door seal
Interior shot, where you'll see it has the desirable velour upholstery fitted
It may lack the essential cow hide, but it does have a full complement of pistons at least. I think that black tube on top is new-ish (whatever it is)
And finally a couple form underneath; those two hole sin centre of picture look alarming
Perfect! Imgur seems to automatically resize for forum posts (if you don't do it yourself). I'm actually glad to see Photobucket dying because I'm fed up with people posting 6MB pics. Whenever I saw that rubbish I would close the tab.
Aaaanyway, that looks very tidy. What holes were you talking about? Because all I can see is the usual sill drains?
But seriously - get some underseal on there because it won't look like that forever...
Sill drains, that what they are! I thought they were too uniform to be rust induced.
Once I relocate it here I'll be instigating a 'must do' plan of preventative maintenance, using knowledge gained on here. I'll start a thread when we get there and harness the collective knowhow.
Sent from my Swift 2 Plus using Tapatalk
Yeah, some of the holes are actually deliberate! :laughing:
That's okay and you're quite welcome to, but just go an buy a can of Hammerite underbody seal (with Waxoyl additive) and go completely nuts with it. As long as you keep it away from the exhaust and heat shields, it's not as though you can go wrong.
Make sure none of your so-called 'mates' glassfibre over them on the pretext of fixing your sills:wrong::angry:
You remember that "hole" in my offside chassis rail that I wasn't sure about? Yeah. That's genuine. The hole that appeared behind it isn't.
Tiger has a year left at most unless that can be fixed. Problem is that it's structural so it might be time to let her die.
Ah yes, he was going to fab up his own shocks IIRC? To get the return he wanted or somesuch. Pretty looking car mind
Hello again.
So, plans are progressing to get my grubby mitts on said motor vehicle. All being well a pal and I will be heading down to NE Derbyshire in a fortnight's time with a view to getting it sorted for an MOT. All very tight time wise as I'm sure you'll appreciate.
However speaking to my MiL it transpires that apparently the blowers don't work. Now I'm fairly sure that's an MOT fail so I'm hoping someone may be able to identify any common and easily checked faults I could maybe get checked prior to heading down. I appreciate the fuse is the first thing to check so could someone tell me which one and I'll see if it could be looked at?
Cheers,
Dabooka
Hi there! Is it just the blower that doesn't work? As in, the rest of the HVAC (and dashboard instruments) are okay?
Thanks for the reply chaps.
Yes, as far as i have been led to believe it's just the blower, all else is fine (initially I thought it was the a/c that had died). For some reason I thought you needed a demister for the MOT so that's a good bit of news!
