Emptied it.............was resembling a rubbish bin, especially with the junk attached to the back end atm, need mine back!!!!! Grrrrr
Wash and brush up, and black polished the black bits. looking good.
If rain holds off might try my first ever attempt at a claybar tonight.
MODS - is this thread worthy of a sticky ?
Well the rain held off so I tried the claybar last night. The car was washed on Sunday and not moved since so it had one days dirt settle on it. Yes the claybar got dirty but it didn't make as much difference to the finish as I expected. Some pressure was needed to get the tar spots off. Anyway it's done now and finished off with a light polish of Mer.You will be amazed at how much crud will come off when you clay bar your car (even after washing). Just use the clay very lightly when using the application spray, no pressure needed at all.
I learnt a lot about the clay. It was harder than I expected (the clay that is).The claybar will take off all manner of rubbish, but if you've got actual tar blobs on there you need to use something else first to remove the bulk.
Be gentle with the clay, use the detailer spray often, and don't allow the bar to "drag". Make sure you keep the bar warm and fold it to present a clean face.
I started to use some white spirit to get rid of the tar, but found if I didn't remove it all the clay then spread all over the paint (there isn't an emoticon for FOOL or I'd put it in here lol). That took some getting off, the detailing spray allows it to come back off, or just wiped it off with a rag in the end. I did drag the clay a few times until I got in the habit with the spray, I also found problems round badges and door trims and washer nozzles . . . and I think I should have turned the clay over more to keep it clean.
Next time will be easier . . .
Nice brake light BTW
The claybar will take off all manner of rubbish, but if you've got actual tar blobs on there you need to use something else first to remove the bulk. I strongly recommend a specialist bug/tar remover. I use Megiuars Gold Class Bug & Tar Remover, but even a dab of raw kerosene will work, (hint: that's what Redex is made of...). Make sure you wipe it off quickly.
Anyway, I replaced Mako's 3rd brake light mask with a silver one today. I think it looks neater* and can't wait for her Mercury "Flying M" badge to arrive in the next few days...
* Also stops people getting up my backside trying to see what it says...
This is what my coug looked like the last time I clay barred it and gave it a polish:
