We drove into Bude in the Kuga and had some ice cream after Tina had played on beach lol
Looks like I may concider scrapping Uncle Fester as his battery has gone flat and I'm getting no where with the install (health issues)
Sent from my C5303 using Tapatalk
Fitted new genuine Ford rear drop links, plus the near side rear ARB mount rubber to match the offside i did couple of weeks ago again the bolt was rusted solid and had to drill it out and put a cap head bolt washer and nyloc nut on to replace.
Also got my Weichers front strut brace which arrived in 7 days from Germany ordered via DC Performance at a very resonable £79.80 :) :) just need to paint it, its currently red i want it satin black and fix it to the car now, it did come with nuts/bolts etc, but i'm going to secure it using 6mm rivnuts i got hold off recently ;)
Mission complete undersealing finally done wish I took some pics of before and after but looks like new underneath know I need to clean everything else just got some meguirars so I will be busy tommorow on my birthday, don't mind polishing the cat though as it will be looking smart again
its taken 5 days and 9 litres of underseal to do the job local garage says I should be able to do it in two guess I put it on a bit thick
Well done Andy now I know what's ahead of me:LOL:
Got the cat back on its feet after nearly 3 months.:sleep: But I must say its looking a lot better.
From this
Swapped VSS for a known working one to see if that would fix the issue with the speedo not reading, didnt work so swapped the clocks with known working good still no movement on the speedo, cleaned the Loom connector still nothing so next week in between searching for a new contract I will be changing the dashboard loom and also need to take engine out of both cars swap the headers and the flywheel and put the quaiffe gearbox on (y)
Thanks for that Andy, i had my eye on that one, but its got the wrong chip in it :( by the look if it it has the later ceramic type chip, the Coog needs the glass 4C chip
Fog lights arrived today I did know before hand that one was badly marked a bit of wet and dry and polish.
Before:
and after:
just the fitting to repair now
