When you've got a solenoid gone/going the locking tries to work on the remote but the good lock opens again straightaway and usually blows the fuse.
the OHC
Can you just fit a solenoid from any car i.e a breaker?
Mine doesn`t do that Andy, drivers door locks and unlocks on the remote, passenger door does nothing at all on the remote but central locking works perfectly on the key in passenger door but sometimes does what you describe above with the key in the drivers door
OHC: overhead console; the earlier ones with 7 lamps included a 'bulb-out' warning.
Any Cougar one should be fine as long as you could test it beforehand, they are door specific and a 'bit fiddly' to do.
Of course. What a retard![]()
Rik on some keys it was possible to change the way they worked, one press of open just did the drivers door, have you tried pressing open once and then press open straight away i.e. two presses on open, you may find it unlocks the passenger door
it was a way of adding security so that all doors didn't open to allow other unwanted's in
just a thought, may not apply
MOT at the end of the week, so it only makes sense that all the stock parts go on to avoid a silly fail!
Rik, if your remote is set up the same as mine,then only the drivers door unlocks on first press on fob. To open the passenger side, you need to double click the fob and then both doors will unlock. This is just a security feature. Mine has been like this since I bought it. I programmed my old Mondy to do the same, although never done it on my Focus, although again it's still possible to do this. So it may not be a solanoid. Give it a try before you start changing anything.
Yup, exactly as mine is set up. Just a security feature, stops anyone from jumping into your passenger side when you don't want them to.
Yup, good idea matey. I actually unplug the high level brake light, as mine says "Cougar" and would fail. So garage advised unplug it and say it doesn't work lol!! Hope you get a lovely clear pass on the day.
I thought you might like it Andy.![]()
They were all originally set up with the double press for the passenger door.
The Cougar can't be changed to single press for both doors, or vice-versa, using the keys but has to be done via the ECU.
