Well, according to the garage I used, if you don't have headlight washers and self-levellers they're a failure. This opinion was echoed by a friend of mine who is an MOT tester, so it seems I'll have to resign myself to removing them once a year from now on.
my bug eye scorpio passed with hid's ,was told u only have to have headlight washers OR self levellers you dont need both and the washers have to work..
ive actually got spare headlights for the coug which the mot man said he'd pass it with hid's so long as ive got them in the boot for him to see...dont know what good it makes them being in the boot but im not arguing.
to be fair on the rules a properly fitted and correct colour hid set should be a pass but all to often u see lads with almost purple hid's in there corsa's with em pointing up in the air...they seem to get a thrill outta beaming them into windows..i think it was the regulators intent to stop this from happening and as usual tarred us all with the same brush.
im gona try fitting some washers to melina later this year...i'll do a how to if it all works out ok..ether that or i'll need a new bumper:LOL:
Fitted new cruise steering wheel all the way from the USA
Can`t upload picture for some strange reason, every photobucket link is an invalid file?
Jacked it up like we used to do to the Capri`s Alan?
No no no no nooo, i never jacked mine up Rik. I always liked em low..........:)
Yes it is Steve. I fitted the long overdue rear ARB bushes today, the poly ones. The original rubber ones that came with the bar were actually standard size squashed to fit and they were well past their use by date. When we did the S97/S600 conversion, iirc Mart had these torks head bolts but i wanted to replace these with hex bolts, and you guessed it, i forgot, so i need to check the bolt/thread size/diameter so i can change them later.
I have recently been getting a bit of really agravating noise from the back, hence:
Old bushes and brackets came off easily, thanks to the recent work done by the gang. (y) Here, old crusty rubber bushes next to the shiney new poly 21mm ones prior to being cilly greased etc and refitted.
Bracket internals and edges cleaned up and cilly grease applied:
fully greased and complete:
Fronts to check tomorrow........
Changed a headlight bulb! A tricky process indeed, the torx screws required a lot of persuasion, had to get a ratchet on them, what a job, doesn't look like they've been opened or removed for years, also switched my sidelights to LEDS from my Skoda, took 10 seconds to take them out the Skoda, an hour to put in the Cougar!
Stuck my IMRC under my battery. I need a longer term solution, but the fact it won't be cooked anymore should stop me from getting my ass handed to me by Honda Civic's.
None of you have seen me angry (and hopefully you never will) - that would have been a good introduction
Initial tests show it still working, so that's positive.
get that st200 setup done...they'll be sooorrryy(y)
A point to note, sir. Once the encapsulation of the transistor is compromised, it will fail when it gets hot enough again, relocation notwithstanding.
It's likely that you just haven't experienced that level of heatsoak since. You've told me what your commute is so that's what I suspect; the only slow bits of your journey are where the secondaries wouldn't open anyway.
The ST200 swap will happen, I've got some prep bits to sort in the meantime but I'll keep you informed! I'm so excited to get it done, but I'm going to wait until it's warmer!
Yeah, I know it's only a stopgap. My new job is down in Southend, so I'm whizzing up and down the A12 and A130, and it's generally been well behaved. When I took it out of it's usual compartment under the rocker cover, the area was ridiculously hot. At least I know I can tie it under the battery now, so that's answered a few questions. It'll be interesting to see whether there's any impact.
I hope you chaps are well :)
Doing well here, thank you mate. And I'm loving being part of your journey. I hope we can all take you where you want to go.
On topic, whoever decided to put the IMRC directly over an exhaust bank needs to be kicked in the balls until they're pulp.
