Cheers Procomm that is good news.
I should probably check the ”spare“ I have up in my attic before I go too much further. Not a lot to be gained by pulling a faulty one and installing a different faulty one, although I don’t yet know what to expect when I strap the multimeter across it, switch contacts or resisistance.
Yeah fit those mini filters, as you know you really don’t want to be chucking oil vapour into the air supply to the engine. I did consider a catch bottle but where to mount it Was part o& the problem. There is no sign of any staining on the breather filters or around them so any oil emitted is minimal so no need a catch bottle / tank.
if u get any oil vapor coming through the cam breathers then your crankcase breather valve(or pcv) is blocked.
these engines take air in via the cam covers which goes down into the crankcase and up through the middle breather oil separator.
the one under the lim..
this goes into the uim via the pcv (the valve that sits in the bit of rubber pipe under your throttle valve) where the oil nicely coats and filths everything up.
if this valve or the pipe where it goes into the uim gets blocked u end up with oil vapor going back up into the cam covers and out the breathers ,weather it goes into the air meter hose or into the filters mabo and i have fitted.
also!
ive found that if that pcv valve gets stuck open with gunk it can cause increased oil consumption and even cause emission problems as the full suction of the intake will pull all the oil vapor through and into the combustion chambers b4 it can settle back into the oil separator.. you often see mayo looking gunk around the oil filler when this is happening.
this is the pcv job...to allow airflow through gently but to shut it off when the engine is sucking hard:LOL:
oh dear im waffling on again....in short clean your pcv and pipes...soak it in a little cup of petrol or white spirit itll clean it up lovely...a working valve will restrict the airflow when sucked on but not completely block it.
the main advantage to the filters is your not taking air from the intake airflow meter or worrying about split pipes....plus it looks good:rolleyes:
honestly fit the filters! it looks great and cleans the air better going into your engines internals
I remember Jim (lucid) fitting an oil catcher to his cougar, problem was that it had a secondary unexpected result of pressurising the heads so it sounded like a bird tweeting when he accelerated. NA engines do not like being pressurised seals are not designed for it
Well as the car is not going anywhere till all the parts for the MOT arrive I decided to recondition the headlights, first I got a McGuire's headlight kit from halfrauds which was crap, two double sided bits of hand sandpaper, a polishing wheel and buffing cream, after half a day made no difference whatsoever, next got a Holt's kit off Amazon, four grades of circular sand paper, a velcro drill attachment, a polishing pad, abrasive cream and a sealing spray, much better although it seems some discoloration is inside the lenses so not 100%, going to attack the spare pair of lights I have at some point as those are very yellow.
Reactions: HogMonster
Cheers Proccom, Yes I read about Lucid’s experience with catch tank. that was one of several reasons why I didn’t go that way. I need to check what, if anything, I did with the centre breather. I think nothing and it was going to be a future improvement. Busy with the 407 today so Cougar is just being ignored, again.
Referring back to # 7122.
What happens if I disconnect the connection from the crank case breather to the UIM.
I‘d need to close the hole in the UIM and fit a breather filter on the output from the PCV.
Anyone tried this .
Surely I get a cleaner inlet system ?
Reactions: shirtyzeus
Anyone tried this .
NO don't do this..
u DO need air pulled through the engine.
The uim particularly where the pipe(pcv) goes in just before the throttle is under constant vacuum so it is constantly sucking clean air through the cam cover filters u have ,through the engine taking with it any blow by (from pistons) or oil vapor that is generated, this is regulated by the pcv as the vacuum in the uim is constantly changing due to engine speed and throttle position.
if u remove it or block it off all that will happen is the vapours and blow by gasses will buildup in the crankcase area and cause pressure(not a lot just a little) u will also start to see oil coming out of your filters and just about every oilseal on the engine will start to weep oil as suddenly there not dealing with a steady vacuum now they have pressure on them....this was a big mistake i made with my first car (mini 1275GT) ,blew the crank seal out.....
and it did it on the m11 spraying everyone within 200 yards of me with oil...
also altho u are right the oil buildup in the intake is a real pain for airflow and gunking up it does have a good side to it!
the intake valves and there guides take a small amount of this oil vapor and self lubricate themselves... without this it would be pure metal on metal especially for the poor ol secondary valve that never sees petrol , ud be taking life off the engine.
all engines lube the top end valves like this😝
if u were to put a catch tank in u would need to put it between the uim and the pcv valve, easy to do and this would catch al the bad stuff including debris etc and allow just enough vapor through....make sure its the sealed type and not the silly china one with a filter on as all they do is suck fresh air in and make farty sounds🤣....the ones u want have a mesh or an arrangement of pipes in them to trap the oil and debris.
the absolute no brainer to a cleaner intake is get rid of that damn EGR valve if u have it..shoving carbon exhaust gasses back in mixing it with the oil vapor is just utter stupid! and i swear ford engineer were all thinking "that will feck it up by 80k or in 7 years"
yes it stops nox gasses ,but in our cars this only occurs at high speed throttle when the engine is ba****d hot...so unless your an environmentalist and are going to thrash it on the race track at combe it don't need it.
oh gawd iv rabbited on again...hope this helps chap!
That’s all great info Shirtyzeus.
I need read all this info through to get to a full understanding of it before any more action.
That will be later. Now I have two salty road crappy cars and soapy water that I need to introduce to each other.
Later update.
I also…..
Pug air filter removed and checked, it’ll do for a bit, banged out the worst of the dust and picked leaves from the bottom of the air box. Also topped up the coolant, windscreen washer bottle and checked the PS fluid level, showing low but sloping drive is misleading so one to recheck. Also topped up tyre pressure on the 3 tyres I didn’t faff about with yesterday.
My Cougar was staring at me with jealousy and hatred, I pretended not to notice. At least she isn’t getting all this road salt.
Maybe next weekend, her time will come.
And, that terrible thing that chucks exhaust gasses into the inlet, that went many years ago.I have no idea what it was supposed to do but it had “I am bad“ written all over it.
That will be later. Now I have salty road crappy cars and soapy water that I need to introduce to each other.
same here 🤣
bloody road salt gets everywhere:mad:
Hi all, just swinging by with a brief but significant update!
Yesterday I found myself with a spare hour and thought I’d get down to the Cougar and set about getting this fuel pump out. So cordless grinder in hand a mate and I set about cutting a wider access beneath the rear seat and got the pump out, got it home and checked it over. Yes it’s knackered. Probably just as well as the return locking cap shattered when we removed it.
So now I need a new pump / seal kit? The locking ring looks remarkably okay. So anyone got a link? I think I found one on eBay but thought I’d check here.
This car WILL be back on my drive this springtime!
Hello Sam, good to hear from you again and pleased to see you're making some progress.
There's several, BN genuine, early fuel pumps like yours on US eBay; this being one of them:
As far as my day has gone, I've replaced my defunct off-side door locking solenoid with a new one and my near-side US spec. rear lamp with one in better condition to my original. (y)
As far as my day has gone I've replaced my defunct off-side door locking solenoid with a new one and my near-side US spec. rear lamp with one in better condition to my original. (y)
whats wrong with the original andy...i can repair em if u want.
Again it always amazes me how time flies! At least the domestic situation has improved re: the house so hopefully I can do stuff for fun this year. Well, a little at least!
Views on this 3rd party offer for 90 quid?
Paul, are you talking about the door solenoids?
The one I replaced kept blowing the CL fuse.
Sam, that pump looks to be ok and it has the same no. and layout of pins in the connector.
Reactions: Dabooka
I suspect Shirtyzeus is talking about the fuel pump. Probably the solenoid too knowing him. (y)
Personally I’d rather go OEM on the pump if possible, let’s be fair it’s lasted 20 years, I bet the pattern part won’t last that long. I’d repair or send to Shirtyzeus.
On a motor/ pump it shouldn’t be much more than brushes. Maybe bearings, unless the impeller fails too ?
If your solenoid is blowing fuses Quicksilver that probably means the coil is shot, which is most of the solenoid.
You're welcome to take it at Combe and see if you can make anything of it. (y)
It has had a previous repair to one of the mounting points, there are a couple of cracks in the lens and the socket for the outer running lamp is damaged.
Oh, this I didn‘t know! Just doesn’t;t prime, and putting 12v across the pins does nothing. Drove in the garage and then appeared to seize after an albeit long layup.
I’ve opted for the cheapo just so I have something to work with next weekend but I’d love to send it down to see what’s what if possible?
