no mot left, it ran out over a year ago
Ive found the best thing to do with the rear discs is to take the pinch bolt off the shock absorber , knock the hub down and out of it then you can turn it towards you , get some stillsons on it to get the t50 bolts off and replace the bolts with the ones from the mondeo
Front discs and pads are no hassle
I put them in both the top and bottom hole inline to the caliper then leverage them around with two screwdrivers (one on top one on the bottom) and it clicks into place
Getting both ends into both holes is usually the problem (as the bishop said to the actress) but I'll try that. Thank you.
Except those weird springs. I could never get the hang of them and getting them in the holes is always trial-and-error. If you have a technique to gettin them in that doesn't involve swearing, ducking and bleeding, I'd love to hear it.
