looked on Ebay and Fordparts and they have the 2 later types of IACV for the newer smaller cc engine but nowhere seems to sell the older type with the spring in the bottom chamber, anyone aware of a shop that does sell these?
Both of these, one with a vertical plug connection and one with a horizontal plug connection, are showing springs in the bottom chamber:
http://www.ebay.com/itm/Idle-Air-Co...ash=item2a54c699e2:g:Po8AAOSwSv1XlBB7&vxp=mtr
http://www.ebay.com/itm/Idle-Air-Co...ash=item2a54c69ac3:g:tBYAAOSwddNXgS19&vxp=mtr
Let's look at it the other way. What do you need to do to your UIM to accept the later version of the IACV?
After all, this isn't a problem that's going to get better.
Ive ordered the one from the USA.
Ill let you know if that finally kills this moose
Paul explains it in post no8 here:
https://forums.ukcougar.club/threads/29864-Anti-Moosing-Kit-Didnt-solve-the-issue
But that's exactly my point. Doing the "why" analysis...
"The earlier engine with the IACV and 90 degree connector produces more pressure than the later engine with the straight connector."
Why does it? Why is it different? Why can't we adapt them to be the same?
Rebuild itLet's look at it the other way. What do you need to do to your UIM to accept the later version of the IACV?
I havnt got the foggiest of ideas, all I know is that when plugged into my diagnostics laptop Gem's cougar is showing 17PSI through the UIM and my Cougar with a later engine is showing 12PSI without knowing what creates this difference in pressure I do not know where to start with adaptions, what I do know is that its not the UIM that creates the pressure as I have swapped my UIM onto Gems car and vice versa and the readings are the same.But that's exactly my point.edit: I realise they're bolt-compatible). Doing the "why" analysis...
